I match drilled a lot of chromoly steel. Then I used the angle grinder to rough cut the H2 and H3 control ends, as well as the airbrake connections, and the control end I'm using to convert the airbrakes from electric to manual. Then all were finish sanded and assembled in little baggies. Next up is to get them TIG welded at a local shop.
