Thatcher CX-5 Build Log
Date:  8-19-2018
Number of Hours:  7.00
Brief Description:  Lower Leg Brackets
An hour at a time over the past week, I've been getting this done. Starting with drawing the patterns for the lower leg brackets, that brace Bulkhead A1 to the forward fuselage skin, then cutting out the aluminum, then redoing both when I realized this particular piece isn't drawn in 1:1, even though the other parts on the sheet are all 1:1. Then I've drilled the parts, primed them, and match drilled the fuselage. Today I got all the brackets in place. Once an interior skin is attached, these will also provide support to the front pilot's lower legs.
