Brief Description: layed up plugs for upper cowl ramps
I discovered that the upper ramps provide a direct exit for upper plenum air to escape to the lower; confirmed by research in the forums. So I layed up some fiberglas plugs over foam. When cured I will eat out the foam, trim, and insert int the sides of the ramps, and then either glass them in or secure with red RTV.
