Steves Web Site
Date:  11-17-2014
Number of Hours:  5.00
Brief Description:  wings assembly
begin work on L wing
removed fuel tank and pressure tested. found 2 leaks at tank access plate
also:
-no anti-rotation plate installed on fuel pick-up tube
-rubber gasket installed on sender (manual says do not install). Gasket was cracked with age in spite of no use.
Above sqwaks (except leaks) were due to revisions to plans after original owner installed plate.
tested fuel pickup with ohm meter, checks ok.
Reinstalled fuel tank, need to order new access plate and gasket and anti-rotation
testing for leaks @ 1psi
access plate w/rubber gasket
