Brief Description: final install flaps and ailerons
installed flaps; dissambeled and honed bearing blocks for smoother operation. Ailerons: adjusted pushrods and linkage to set correct bellcrank angles and alighment with flaps and wingtips. Torqued and marked all nuts.
At this point aileron, elevator, rudder, and flaps all work smoothly and perfectly and are aligned and secured properly. Also tested aileron and elevator trim for proper operation.
