I discovered that my original installation of the boarding step did not allow enough clearance from the rudder cable. Relocated plastic end mount lower to get clearance, and made a doubler to compensate for extra holes drilled. Also needed to fab spacers on the outside as new lower positon created a gap at the bottom, which will be concealed by the fairing.
