Qty Description1 Airhose and Manifold block kit1 Rapid Air Crompressed Air Piping Kit1 Sioux 1/4" Air Drill1 Baldor Buffer1 C-Frame Riveting Tool1 C-Frame table Riser4 6" #30 bit4 6" #40 bit1 Tight Fit Dimple Fixture1 3/32" Close Qtr. Die Set1 Substructure 3/32 Dimple Die Set1 Tank Skin 3/32 Dimple Die Set1 Dimple Die and Set Kit1 Quick change tooling kit1 12" back rivet set for c frame1 3.5" back rivet 1 Main Squeeze - Model 221 3" Pneumatic Yoke1 2.5" Flange-Nose Pneu. Yoke1 1" Thin-Nose Pneu. Yoke1 Swivel Head Pop Rivet Tool14 1/8" Wedge-Loc Fastner 25/bag30 3/32" Wedge-Loc Fastner 25/bag1 3/16" Wedge-Loc Fastner 10/bag1 5/32" Wedge-Loc Fastner 10/bag10 1" Cleko Clamp10 1/2" Cleko Clamp2 Cleko Pliers1 Back Rivet Tape1 Rivet Tape Dispenser1 3M Riveters Tape1 24" Stainless Ruler1 6" Stainless Ruler1 10" curved file1 File Handle1 Countersink Cutter - #10 Screw1 Countersink Cutter - 3/32" Rivet1 Single Flute Countersink Cutter - 1/8" rivet1 Single Flute Countersink Cutter - #6 Screw1 Single Flute Countersink Cutter - #8 Screw2 Micro Stop Notched Countersink1 3M Screw On Mandrel1 3M 1/4" Mandrel2 3M Cut & Polish Wheel - 1"1 3M Cut & Polish Wheel - 2"1 3M Cut & Polish Wheel - 6"1 3M Light Deburring Wheel - 6"1 Tapered Alignment Punch1 3" Hex Deburring Tool1 10" Hex Deburring Tool1 3pc. Aluminum Deburr Handle1 Edge Forming Tool1 Sharpie Marker 4-Pack1 Air Swivel / Regulator20 3M Scotch Brite Red Hand Pad1 RV14-A Hangar Banner1 2" Precision Square1 #6 Nut Plate Drill Jig1 #8 Nut Plate Drill Jig1 Klenk Rt. Offset Snip (Grn)1 Klenk Lt. Offset Snip (Red)
