Daniels Web Site
Date:  2-17-2006
Number of Hours:  10.00
Manual Reference:  8-8
Brief Description:  Foreward Fuselage
Fit and drilled auxiliary longerons to skins. Fabricated angle clips to hold forward skin stiffeners. Fit and drilled stiffeners to skin. Fabricated lower longerons, fit and drilled to skins. Drilled bolt holesthrough lower longerons and firewall brackets. Fitted and drilled 684 gussets to firewall and lower longerons. Fit and installed the forward bulkheads. Fit and drilled gear attach webs to skins, longerons, and forward bulkheads. Fabricated spacers for fuel tank brackets, Installed and drilled fuel tank brackets to gear attach webs.Started work on rudder and brake pedals.
Interior Forward Fuselage
