Brief Description: Continued Rear Spar Assembly work
Deburred rear spar components
final drill, debur and dimple the rear spar inboard flange over the W-707G Reinforcement fork
dimpled the spar and doubler plates on the left spar. Not sure if this is correct as it seems the squeezer distorts the doubler plates while dimpling. Used the hand seamer to get the angle back. Hope it works :-|
