Brief Description: Center Section - Fitting F-715 Ribs
Worked on getting the F-715 ribs alligned and drilled. Proved to be a tedious task. I would either under/over flute the flange to the point where I was beginning to think I was going to wear a hole in the flutes. Presistance pays.
Left F-715 Rib shown in place
Right F-715 Rib showing the hole alignment marks so as not to flute where a hole will be drilled
Left F-715 Rib, fwd flange trim mark for fit in F-704B
