Brief Description: Primed the center section ribs and bottom skin
Probably a bit too cool (48 degrees) to be spraying rattle can self-etching primer (Rust-Oleam) butI did it anyway. The dry/cure time was extended but I think this extended time allows the bonding of the primer to the aluminum to be better. May be a false sense on my part but only time will tell.
