My RV-7A
Date:  4-23-2009
Number of Hours:  1.50
- Modified the inboard fuel tank rib by cutting out the access hole using a flycutter on the drill press. (DANGEROUS TOOL!!)
- Drilled the screw holes and deburred
- Drilled nutplate holes, deburred and dimpled the rib where flush rivets fit.
- Machine countersunk the T-407 stiffener ring nutplate rivet holes to accept the dimpled rib.
- After riveting one nutplate in place, found that machine countersinks were not deep enough to accept dimpled rib. Will correct tomorrow.
