My RV-7A
Date:  12-30-2008
Number of Hours:  5.00
Brief Description:  Rivet tie down assembly and attach bell crank asse
Attached the tie down assembly with its fabricated spacers to the right wing spar. Note that I primed the area where the tie down spacers touch the wing spar. Also attached the bell crank brackets as indicated in the plans and builder's manual. Then did the same thing for the left wing spar.
