Brief Description: Elevator leading edge rolling part deaux
Re-rolled the leading edge of the left elevator. This improved the pillowing experienced during prior attempts. Still some pillowing between the rod-end bearing cut-outs. Clecoed the edges together. Overlap looks good and the dimensions are ok. Match drilled (#40) and clecoed. Going to sleep on it before commiting to riveting.
