Finished riveting the left HS stab skin to the front spar and ribs. Starting at the leading edge, drove rivets from front top toward the rear, flipping between the top and bottom left HS stab every two rivets to "cheat" the skin towards the back. The prepunched skins allowed me to not have to use a jig. Only used a couple of 2x4s to keep the clecos off of the table while riveting. Will use the same method on the right side of the HS stab. It also helps to have help.
