My RV-7A
RV-7A
Front Spar Assembly
Trimmed the inboard ends of the HS-702 as required for the RV-7 since the spare is manufactured for an RV-8.
Drilled #30 relief hole 1/8th inch inboard of the bend line and centered on the bend radius of the flange.
Bent the flange tabs to 6 degrees and clecoed the HS-710 reinforcement angle and the HS-714 splice angle to spars.
RV-7A Home
255
Ailerons
94
Fuel Tanks
Shop
Technical Counselor
Tips and Tricks
