My RV-7A
RV-7A
Front Spar Assembly
Match drilled all holes inboard of the rib attachment points on the HS-404/HS-405.
Tapered the ends of the HS-710 and HS-714.
Bent the HS-710 and HS-714 ends to 6 degrees.
RV-7A Home
255
Ailerons
94
Fuel Tanks
Shop
Technical Counselor
Tips and Tricks
