My RV-7A
RV-7A
Manual Aileron Trim Assembly
Drilled the bolt hole and carter key hole in the aileron trim weldments.
Center It did not work in my bench drill press w/6 inch bits :-(
Good'ole standby and a steady hand works every time.
Whalla! Not dead center or straight but it will server the purpose
RV-7A Home
255
Ailerons
94
Fuel Tanks
Shop
Technical Counselor
Tips and Tricks
