Steves RV-12 Web Site
RV-9A
Forward Fuselage Prep and Assembly
1. Rivited outer seat ribs to center bottom skin. 2. Drilled pitot line routing hole 3. Rejoined center section to rear fuselage 4. Rivited platenuts to baggage vertical ribs 5. Clecoed armrests, horizontal and vertical ribs to center fuselage. 6. Rivited inner rivites on F704H L&R to F9070 L& right skins. 7. Installed platenuts on F684 L&R gussets. 8. Insalled platenuts on F902 L&R bulkheads 9 Riveted F684 gussets to firewall 10 Riveted F719B L&R angles to firewall 11 Painted F902 L&R side ribs 12 Attached an clecoed firewall assmebly to center fuselage 13 Riveted F719B L&R to F719 L&R stiffners 14 Riveted F910 L&R gear attach webs to F902 L&R bulkheads 15 Riveted spacer to F998C L&R and F910 L&R gear attach web.
RV-12 Home
RV-9A Home
1224
292
368
Hardware
Instrument Panel
550
