Installed fluid fittings into fuel pump. Installed fuel pump to the facet pump bracket (Left bolts loose for final adjustment when installing fuel lines.). Drilled fuel valve handle, as directed. Installed the red knob to the fuel valve bracket handle, as directed. Installed the other end of the fuel valve bracket handle to the fuel valve handle as directed. Installed the upstream fluid fitting to the fuel valve. Installed the downstream fluid fitting through the fuel valve bracket and into the fuel valve aas directed. Riveted the fuel valve clip as directed. Riveted the fuel valve bracket to the bottom skin as directed.
