Brief Description: Left Position Light Access Cutout & Landing Light
Layed out, cutout, and deburred position light access opening in left wing tip. Drilled #19 hole in left wing tip, next to position light access opening. Wrapped masking tape around each end of the landing light lens then inserted into the opening in the outboard wing skin of the right wing. Realized I did not have a #30 drill bit for plexi-glass, and removed the lens. Removed protective vinyl from and deburred landing light lens backing strips.
