Fabricated wing tip tab bending tool, as directed. Removed protective vinyl and deburred left wing tip close-out panel. Bent left wing tip close-out panel tabs as directed. Clecoed and riveted left wing tip close-out panel to wing. Removed protective vinyl and deburred left wing tip trailing edge. Match drilled left wing tip trailing edge to wing tip aft skin. Clecoed and riveted left wing tip trailing edge to left wing tip aft skin, wing tip rib, and wing tip closeout panel. Repeated left wing tip close-out panel and left wing tip trailing edge procedure for right wing.
