Brief Description: Rear Bulkhead Hinge Brackets and Flange Bearings
Final drilled clecoed hinge brackets, flange bearings, and rear bulkhead assembly. Riveted flange bearing to rear bulkhead assembly hinge brackets. Assembled hardware required to check fit stabilator and rear bulkhead assembly.
Right flange bearing and hinge bracket riveted to rear bulkhead
Left flange bearing and hinge bracket riveted to rear bulkhead
