TIM'S WEB SITE
Date:  2-19-2019
Brief Description:  Rudder
Trial fitted the rudder skin today. all clecos in bar 2, the same hole on both sides of the rudder is partialy blocked by the bracked behind the skin. I will have to remove the skin and try to work out how to rectify this.
The skin trailing edge is sitting slightly out from the end rib so I need to remove the rudder frame and slightly close up the skin to make it sit flush.
Rudder skin clecoed
Rudder skin clecoed
Same hole on both sides
Need to close skin slightly
