Trial fitted the rudder skin today. all clecos in bar 2, the same hole on both sides of the rudder is partialy blocked by the bracked behind the skin. I will have to remove the skin and try to work out how to rectify this. The skin trailing edge is sitting slightly out from the end rib so I need to remove the rudder frame and slightly close up the skin to make it sit flush.
