Fabricated the remaining half-round fuselage gussets from 1/8" Okoume plywood for the bottom fuselage truss. Fabricated 4 x 4 x 3/4" marine plywood blocks for later use in main landing gear mounting. Also, fabricated remaining 3/4" plywood blocks to be used as intra-longeron filler blocks between the double lower longerons.
