Applied top plywood between stations 5 and 6. This plywood serves as a gusset for this area, and also as the baggage compartment floor. 1/8" Okoume plywood was used. The plywood was rough-cut, T-88 was applied to longerons, bulkheads and crossmembers. Staples were used to achieve clamping pressure. Once the wood was installed and the epoxy dried, a router with a flush-cut bit was used to "clean up" the edges.
