Attached/installed SafeAir firewall pass-thru kit to lower RH position and ran wires thru said. Positioned oil pressure transducer to upper LH engine mount tube with appropriate clamps and attached to oil outlet port on accesssory case with restrictor to prevent oil loss in the event of a leak. Ran remaining wires thru firewall, magneto with EGT indication and fuel primer only ones remaining.
