Fitted flap motor and rod end bearing safetied to actuator as per plans. Attached WD-613-EF actuator arm and attached assembly to F-766A channel. Tested system with battery and works satisfactory. Fitted F-760 forward actuator covers which completes fuselage construction. Wing mate and gear legs are next!
