Riveted nose ribs to main spar. Dimpled rear spar and ribs in preparation to install W-902 Inboard Wing Panel and wing walk doubler. Had to remove tank for second time to set upper W-912 Rib flange rivets. Tough long day with a lot of riveting. Thank goodness for tungsten bucking bars. Does the same work in half the rivet gun hits.
