This log entry is for the period 7/23/2013 thru 8/22/2013.
Fueled aircraft and test ran engine. No leaks noted. Engine ran rich and subsequently pulled carburetor and sent for re-overhaul. Also found primer solenoid reversed due to internal check valve. Reran engine and noted improved idle quality, adjusted mixture and idle speed.
Fitted LH wing tip and root fairing. Constructed RH wing push pull tubes, hung LH aileron and flap assemblies.
