My RV-7A
Date:  4-11-2012
Manual Reference:  VP-X Pro
Brief Description:  Vertical Power VP-X Pro Test Bench
Received my Master and Starter solenoids today.
Installed the solenoids on the bench.
Installed the diodes and fabricated a power bar between the Master and Starter solenoids.
Installed the power lead to the Master and to the VP-X Pro.
Grounded the Starter solenoid.
I temporarily wire in a switch as the master and powered the system up.
I checked voltage throughout the circuit, showing 13.93 volts.
I will be fabricating a mount for all the switches tomorrow... and start pinning out for the VP-X.
solenoids Installed on Bench
Powered UP 13.93 volts
