My RV-7A
Date:  6-15-2012
Number of Hours:  2.50
Manual Reference:  Lyc. Maint Manual
Brief Description:  Oil Cooler Fittings / MAP P-Mags
Installed the oil cooler fittings on the accessory case.
Fabricated the MAP line required for the P-Mags by tapping off the #4 cylinder.
I Tee'd off through the baffling as pictured in photo #2.
I am feeling good about the design, ridged and heat resistant on the engine side...
I will use the stock MAP tubing that is shipped with the P-Mags and see how things work.
The P-Mags also require blast tubes be fabricated to cool the mags.
MAP line off #4 Cylinder
Tee on Accessory Side
