My RV-7A
Date:  1-6-2012
Manual Reference:  Lyc. Maint. Manual
Brief Description:  Engine Assembly
Began by lubricating and installed the drive gears.
Double checked the timing and all the plugs.
Installed the fuel pump push rod.
Installed and sealed the gasket.
Installed and torqued the accessory drive case.
Went to the airport to pick up some parts...
New oil drain back tubes.
Inner cylinder baffles.
Oil suction screen.
Intake hoses and clamps.
All Timed Up
All Timed Up
Accessory Case Insrtalled
