My RV-7A
Date:  1-10-2010
Number of Hours:  1.50
Manual Reference:  Sec 7-6 DWG 16A
Brief Description:  Countersink / Match Drilling
Machine countersink the spanwise rows of holes in the T-701 tank skin (not the baffle) that attach the skin to the T-702 baffle. Have the baffle in place so that the pilot has a good hole to guide the countersink. This makes it easier to slide the baffle into position on final assembly.
Drill the spar attachment screw holes and the W-423 screw holes to final size using a #19 drill.
Disassemble the tank, marking all parts so they may be easily returned to the same location.
I completed the countersinking of the skin for the rear baffle attachment.
Final drilled the #19 tank to spar attachment. Deburred.
Right Fuel Tank in Cradle
