My RV-7A
Date:  7-13-2012
Number of Hours:  3.50
Manual Reference:  Sec 9 DWG 46A
Brief Description:  Engine Sensors / Enigne Mount
Installed CHT probes in the cylinders.
Installedd EGT probes approx 2" down on each exhaust pipe. 3 installed waiting for 4th from Dynon as mentioned earlier.
Installed carb air temp sensor.
Installed the oil temp sensor.
Fitted the engine mount to the fuselage... started by lining and clamping everything in place...
Match drilled the top and bottom corners to 3/16" and made some bushings for the inner engine mount holes and bolted everything tight in place. Check for square and clearances.
Had to fabricate 2 spacers for the inner mounts as pictured in Photo #2, this squared everything up and allowed clearance for the boost pump mount nut plates. Once everything was in place and tight. I drilled each hole to final size...
Temporarily Installed
Spacers for Center Mounts
