My RV-7A
Date:  7-31-2010
Manual Reference:  Sec 7-9 DWG 13A
Brief Description:  Left Aileron
Began sorting out the aileron parts...
Installed the left mounts to the hinge points with proper washers / bushings etc.
Fitted the left aileron, and cleco'd to the left wing to check clearances etc.
I wanted to see how everything fit... The only issue I see is the outed hinge is not exactly perpendicular, although clearances are fine and the aileron moves smoothly... Does not seem to be an issue, but I will need to do a little research...
Other than that everything fit great...
