My RV-10
Date: 3-31-2020
Number of Hours: 3.50
Manual Reference: 8-1,2,3
Brief Description: HS Rear Spar
Fitted the rear spar doubler, drilled, deburred, primed and riveted in place. fitted hinge brackets, deburred, riveted in place. Fitted inboard hinge and VA-146, drilled, deburred, bolted and torqued to specs.
HS Rear Spar
