Bob's RV-8 Build Site
Date:  12-9-2021
Number of Hours:  4.50
Brief Description:  Park Brake and Alt Air Cable Mod
I was planning on putting the ALT AIR Cable for the induction system through the gear tower but while pondering where I was going to place it I became torn between the gear tower and putting it with the Park Brake cable.
I did a lot of looking and measuring and thinking and in the end I finally decided to put it on the gear tower with the parking brake cable. So I began to remove the cable and bracket and re-measuring and designing the new bracket......by quitting time I had the bracket mostly made. I had to do a lot of measuring to use the same holes in the gear tower and with the two cables I decided to step up to #10 bolts from #8 screws.
Making Bracket for cables
