Tonight I decided to drill the holes for the heater box. I marked them and started with the large hole figuring if that ended up being a little off I could adjust where the #3 bolt holes could be drilled, but the opposite would be difficult to do. I drilled it and then remarked the attachment holes as there was a slight shift. Then I drilled the #3 holes and deburred all the holes.
