Brief Description: Fuel valve bracket and Mid cabin cover
I wasn't finished with the screws for the fuel valve support so I started with completing those items.
Next I decided to make a pattern for locating the cup holder I ordered from Amazon Aircraft Supply warehouse. Once again using the trusty old poster board I was able to locate where I wanted the cup holder to sit. I had placed my side console on as well to see if it interfered with having a bottle in the cup holder which it doesn't . The cupholder will fit a standard soda can or a 16.9 oz/500ml water bottle. I can't imagine ever drinking that much during a flight because my system won't support that kind of fluid intake with having to make physiological flight decisions. So the cupholder was very inexpensive (after looking at myriad of other "cooler" cupholders) and it will work great and had one of the smaller signatures to not have to make a monsterous hole.
I also received two boxes today. One had my Fuse Block and pins and the other was my Airflow 13 row Oil Cooler, plenum, and bracket kit....more work!
