Bob's RV-8 Build Site
Date:  4-18-2020
Number of Hours:  3.70
Brief Description:  Design and make parking brake cable mount
I had just a little left to do on the brake lines and completed that.
I realized in the process that I never thought of making the bracket I need to hold the parking brake control cable for putting the parking brake on and off. So I began to measure and design a bracket that I felt would do the job of holding the cable in such a way to smoothly activate the brake module control arm.
After pondering and coming up with a design, I made the bracket. It always seems slow when you are trying to get the design figured out and then the manufacturing of it still involves making modifications on the go. Anyway...I designed and made it this session and think it will work well.
I went ahead and torqued the fuel lines and called it a night.
Completed brake lines
