Bob's RV-8 Build Site
Date:  4-15-2020
Number of Hours:  1.50
Brief Description:  Remove Fuel line plan fuse block area
I really didn't like the fit of the long fuel line that travels along the spar center section so I removed it and bought more material to remake it. At least I had the old one in order to use that as a pattern. I removed the old fuel line and then diverted.
I am pondering where I want to put the fuse block that will power and protect the "non essential" items in the electrical system. Since I designed different consoles for the airplane I will not be using the Vans provided switch side console. I am pondering how to best use the rivet holes that are available to make a decent location for the block.....we will see....more pondering.
Old fuel line...new material
Potential site for fuse block
