Bob's RV-8 Build Site
Date:  6-18-2019
Number of Hours:  2.20
Brief Description:  ELT Bracket #6
I completed getting the mount and hardware installed and torqued to the right specs.
Next I took the foam pieces I made to make a foam block and lay out for the fiberglass cubby I am making for the mid cabin cover for a little storage. I mixed some dry micro to use as a bonding agent between the layers of foam. After getting all the pieces slathered with micro and put together, I set it off to the side and placed a heavy tub of clecos on top to let it set.
I took a few minutes to look at the Vans static kit installation.
ELT Mount installed
ELT Mount installed
Making a foam block
Making a foam block
Reviewing static system install kit
