I cut the main profile angle to form the side of the right console. As I was laying on the standoff angles that are attached to the spar channel I realized that the standoff angles were cut a little too short for my liking. They would have functionally worked....but I wasn't happy with them so I took time to remake them. They are made of 1/8 alum angle but I machined half the thickness away from where the side angle will rest in order to have the the top of the console lay flat at the same level. Worked great.
I rough cut the angled front panel. I driled and clecoed the support angles and the side angle to start getting the frame set in place. Will fit the forward angle panel next session.
