Bob's RV-8 Build Site
Date:  3-11-2019
Number of Hours:  2.80
Brief Description:  Quad and Console #14
After returning from a work trip I got back into the shop. I had to get the console installed once again in the fuselage after removing it to install all the nutplates etc.
After getting the console installed I began to measure and write down dimensions in order to make a pattern for the top of the console. I like using poster board as it is stiff enough, but not too stiff that it seems to really make a good pattern to trace on the aluminum.
By the end of the work session I had the pattern cut and traced on the aluminum sheet.
Left console reinstalled
Another photo angle
Another photo angle
Pattern for top made and marked
