Brief Description: Engine Cable Routing in Gear Tower
I measured and marked the hole locations for routing the engine control cables through the left gear tower. I attached a string to the throttle and the firewall cable holes. It gave me an elevation of wher on the tower I wanted to drill the carry through holes.
Next I made and cut out a hole location template and decided where it needed to be placed on the tower. After pondering for a bit I was satisfied with the location and taped it to the area and used the center holes to mark the locations of the holes.
