I spent some time just looking over the areas where the side consoles are going to go. I have the concept from my friend Rick's RV-8 although the actual design will be a little different due to how our throttle quadrants are mounted, etc.
I started measuring and drawing the approximate dimensions of the panels. It was while pondering the design, I realized the Manual Aileron Trim would have to be addressed. The manual trim setup has a panel against the left side wall that attaches and contains the trim lever. After pondering I took dimensions from the old plate and determined that I would have to simply attach it to the new console panels I was making and will cut the radius slot on the new panels I make. Anyway that was a session of cypherin!
