I did more checking of the canopy windscreen fit and positioning. Overall it is pretty good but the flange that bolts to the longeron was bent up slightly. I used a small vise with aluminum angle on the jaws to protect the weldment while tweaking the flanges. After a little adjustment the fit is good to go so I removed the frame and began clearing everything out of the fuse. Next step will be cleaning the fuse in preparation for painting.
