After getting everything lined up and prepped I for drilling the outboard 3/8 holes for the right gear bracket and wear plate. I decided to make up a pilt drill bushing to center the hole in the bracket and help assure that the 3/8 drill would have something to guide it in the proper location.
The pilot hole worked well and before you know it the holes were drilled.
